You possibly think my rear spoiler is an abomination. Each to their own!I feel personally attacked![]()
You need to balance it out with some nice carbon grillesYou possibly think my rear spoiler is an abomination. Each to their own!
225 still look (on 18's some 428's have) fairly cheap ~ £100 ... but looks like 255's now £200+in September 2021 I paid £543 for 2x 255/35/19 and 2x 225/40/19 PS4S, fitted, for my 440i.
will you get any insurancefrom mytyres.co.Uk £783.76.
428 will want 225/45R18, not 225/40R18 you've linked.225 still look (on 18's some 428's have) fairly cheap ~ £100 ... but looks like 255's now £200+
.... what's up with the jump, does a smaller stronger sidewall have significantly different manufacture.
Thought I’d bring this up to date. I have a cabin air filter to swap over (not sure if it’s under the drivers side or passenger side on a RHD 4 series) and I still haven’t fitted the diffuser. I also think I will likely eventually take off the M4 style spoiler and go for the smaller version, most likely in gloss black.
Nothing else has gone wrong, the MPS5’s have bedded in nicely and now that the weather is improving I’m able to push a bit more with peace of mind.
Can’t say I’ve noticed much difference in the steering tbh. Have you checked your pressures? If they’ve dropped a bit, or even need putting up a little it might feel slightly woolly as the sidewall flexes too much?How are you finding the PS5s?
I’ve put them on my 135i and have immediately noticed how much more dull the steering is.
I haven’t, no. Since they’ve just been fitted (days ago) I assumed they would be correct, but probably worth a check.Can’t say I’ve noticed much difference in the steering tbh. Have you checked your pressures? If they’ve dropped a bit, or even need putting up a little it might feel slightly woolly as the sidewall flexes too much?
Brave man putting that much trust in a garage.I haven’t, no. Since they’ve just been fitted (days ago) I assumed they would be correct, but probably worth a check.
Did you check your pressures?I haven’t, no. Since they’ve just been fitted (days ago) I assumed they would be correct, but probably worth a check.
Deffo check pressures.
Looking around for insurance as mine will be due in late June. Some of the prices are absolutely wild. £629 or £647 for an annual policy. Nothing has changed!
Are you in start stop traffic? (Well, more stop than start judging from those mpg figures lol)Nice update.
My 440i is currently saying 16mpg. Did 160miles to last tank.
Only doing school runs in it as I'm technically medically banned from driving further than 5 miles at a time.
Nice update.
