Shame they seemingly broke PES and that a mess with this patch now lol.
Have they?
Yeah annoyingly. There things that just don't work, it doesn't record and people are finding that their bodies when they get back to them are just in undersuits. Anything that you have not used in your inventory that you collected isn't being saved between patches and similar. So yeah things are not really persisting as such properly at moment.Have they?
It is to do with if you say do a bunker run, collect stuff and put it in your inventory and never touch it, come next patch/update be major or minor you will loose it unless you have equipped it at least once and then put it back in inventory. Also it has to be main landing location inventory otherwise PES is not recording it at moment, they said they spotted this issue with 3.19 roll out but not clear if it means always been case or just something changed in 3.19.You had me worried there so i logged in to check my gun rack, its all still there.
They have said they are going to be more aggressive with PES clean-up.
Edit:
Oh... not good.
PES is not meant to save items between patches. thats the job of the LTP system.It is to do with if you say do a bunker run, collect stuff and put it in your inventory and never touch it, come next patch/update be major or minor you will loose it unless you have equipped it at least once and then put it back in inventory. Also it has to be main landing location inventory otherwise PES is not recording it at moment, they said they spotted this issue with 3.19 roll out but not clear if it means always been case or just something changed in 3.19.
They have literally come out saying PES isn't storing the information to their system which should be on the entity graph PES utilises. LTP is PES by way. It is long term persistence that is using the entity graph. That is why it is a separate service. The entity graph feeds this. Where do you think it is stored otherwise if not with the entity graph?PES is not meant to save items between patches. thats the job of the LTP system.
LTP stores it and thats what gets persisted through each patch(when it works lol)They have literally come out saying PES isn't storing the information to their system which should be on the entity graph PES utilises. LTP is PES by way. It is long term persistence that is using the entity graph. That is why it is a separate service. The entity graph feeds this. Where do you think it is stored otherwise if not with the entity graph?
One of the servers i was in, EU 270, was like this, so i joined a friend in another server, EU 170, and it was perfect for 4 hours.... and 30K'ed.Feels pretty bad so far.
Keep getting teleported off my ship back to the ASOP area when I go to sit down in it.
30ks. ASOP terminals not working.
The above LTP issues. Presumably why I keep waking up at Area 18 and not where I logged off, and losing inventory.
Been playing on the eu 120 server since 2pm today and no 30k crashes whatsoever.Feels pretty bad so far.
Oh yeah? I was on yesterday. Haven't tried yet today. Shall see how it is after work. Hopefully gets resolved then.There's apparently a bit of service disruption right now. Shame, as it was golden for the first couple of days.
Anyone have a 7800x3d with a 7900xtx at 1440p ? How does it run FPS wise?
