Only if you use a 60Hz monitor or don't mind low settings imo, the 3060 is a fairly weak card especially now.the 3060 is an excellent 1440p card using optimized settings per game
We're all different with different tolerances, yours might just be on the lower end. I can't stand anything below 80ish now, been spoiled by high-end cards! I do game at 4k though (which is an absolute pig still!!).Played GoTG at 1440p with high settings just fine. I wasn't counting the frames but it felt nice and smooth to me.
Probably, but I know I was getting at least 60 because it didn't see any judder, which I can be very sensitive to, especially in panning shots. Seeing I play on an older LG OLED with a 60Hz panel it does me fine. Even when I upgrade to a 120Hz panel in a year or two I know I can just turn on VRR and as long it stays over 45fps I won't see any judder and I'm golden. Calling it a weak card is disingenuous franklyWe're all different with different tolerances, yours might just be on the lower end. I can't stand anything below 80ish now, been spoiled by high-end cards! I do game at 4k though (which is an absolute pig still!!).
IMO everything under the 4070 Ti should be considered a tier lower so the 4060 Ti should really be the 4060 and the 4060 should really be the 4050 Ti. IMO when the 4080 12GB got shifted down in name/price they canned the real 4070 Ti and the rest of their line-up was moved up in name/price to meet it.4060Ti is looking grim. Sad really because the 3060Ti was arguably the best card of the last generation.
The whole 4000 series has been a real disappointment outside of the 4090. Makes me wonder what 5000 will do. It will have to be a substantial improvement. Can’t have the 5060ti being 10% faster than a 4060Ti which was only 8-10% faster than a 3060Ti :S
Probably right, though while 12gb on the 4070 is underwhelming, on the 4070ti it looks absurd. The 4070 seems like the only somewhat decent option beneath the 4090 to me tbh (in between the two the 7900xt seems the best), and at rumoured prices the 4060 looks unlikely to change that.IMO everything under the 4070 Ti should be considered a tier lower so the 4060 Ti should really be the 4060 and the 4060 should really be the 4050 Ti. IMO when the 4080 12GB got shifted down in name/price they canned the real 4070 Ti and the rest of their line-up was moved up in name/price to meet it.
I've not looked to deeply, as in not at all, but i suspect if you compared benchmarks there'd be a bigger gap in performance between the 4070 Ti and non-Ti version than any of the other cards in their line-up.
One thing to add: if you need the performance of a card that is outside the optimal ratio of price/performance, it doesn't really matter that another card is (significantly) cheaper. So who needs the 4090 performance, won't look at 7900xt since is just too slow (basically irelevant).Charging £1,579 for a GPU will do that.
Just to clear something up, the 4090 is not good value.
It costs around £9.40 per frame at 1440p (based on 1% low of 168, MSRP price).
The RX 7900 XT costs around £5.76 per frame at 1440p (based on 1% low of 130, price £750).
At 4K, cost per frame is £9.61 for the RX 7900 XT and £13.73 for the 4090.
If they drop the price of the RX 7900 XT further (e.g £700), the value of the 4090 will look even less favourable.
It's not a relevant card to the vast majority because of it's very high price.One thing to add: if you need the performance of a card that is outside the optimal ratio of price/performance, it doesn't really matter that another card is (significantly) cheaper. So who needs the 4090 performance, won't look at 7900xt since is just too slow (basically irelevant).
Someone is in a pleasant mood.What are you prattling on about? What precisely is not even really true?
Say that back to yourself a few times and then see if your original post stays the same£2k even the most loyal surely will start questioning that
And here's Nvidia's response to the whole VRAM thing: https://www.nvidia.com/en-us/geforce/news/rtx-40-series-vram-video-memory-explained/
TL;DR version: "4000 series has more cache than previous gens, and we offer tools to lower VRAM usage".
What a world we live in...
$399 for a 1.15x improvement over the previous generation
NVIDIA GeForce RTX 4060 Ti and RTX 4060 announced - Pricing, Specifications, and Performance
VideoCardz has obtained significant insights into NVIDIA's forthcoming GeForce RTX 4060 Ti and RTX 4060 "Ada" graphics cards, gleaning this information from the NVIDIA press-deck. ...www.guru3d.com
