Yeah I’ve not turned expo on yetOnly time I've seen invalid scores is when I've pushed an oc too hard and flaked the test out.
Have you got expo off as well? CPU score is too low
How come? You've updated the bios I assume so no reason not to? You can set voltages yourself if you are that worried about it?Yeah I’ve not turned expo on yet
I’ve not dived back into the bios since installing windows, will probably get around to it t some point in the near future.How come? You've updated the bios I assume so no reason not to? You can set voltages yourself if you are that worried about it?
My other thought was maybe it didn't like the ram but if it's base timings I don't think it would cause that?
ive not run cinebench but id say yes as your timespy cpu score is 1500 below my stock expo cpu scoreOnly time I've seen invalid scores is when I've pushed an oc too hard and flaked the test out.
Ultrawide monitor.Well just ordered another item for my gaming setup that costs about as much as a gpu, going to have to wait a couple of weeks for it to be delivered. Any guesses?
Good guess, I'm voting the same way, my xtx nitro was 1079 and my monitor was 999Ultrawide monitor.
Ultrawide monitor.
I’ve been reluctant to seeing the issues with the cpu/motherboard dying, going to wait a bit before I do it.why dont you turn on EXPO, takes like a 30 seconds and check the difference
Is that on the latest bios?Same mobo and cpu as you :
Time spy ( cpu score ) 13232 - so same as yours really
Cinebench 17800 - a lot more than yours.
Strange that it differs.
yeh, 1616Is that on the latest bios?
I’m on 1602 hadn’t checked agin till you just mentioned it, will update it later and see if that does anything.yeh, 1616
Yes I’ve done it, seems the cam software/having dual infographic causes higher “idle” temps. Was getting 40-60c(usually low 50) on the desktop, not having the cam software running/single infographic gives in the 40s. Still need to peel of the plastic from the screen on the pump, was running cinebench single tread test in the picture below.First off, very nice build.
Have you rotated the display on the Z63 yet?
You should be able to do this in the CAM software.
Rotate that display
