Hi Mate,You said pny 4090 aggghhhh I've one coming Tuesday..
How is your PNY for coil whine? Thanks
Which Motherboard are you using?100% it certainly shouldn't be an issue. My PC I've spent quiet a bit making it look really good, so don't like the idea of hiding it in another room either.
What this has made me realize is I won't be day one for the 5090 cards. I'll wait for user feedback (from people sensitive to it only) and if they all have it my 4090 will be more than enough for a long time. I really did need to upgrade this gen as im driving a 77inch oled 120hz screen.
Honestly I'd rather silence over performance, especially now. It was a hassle and a half getting what I have but knowing I've got a silent high performance gaming machine feels really good. Nothing is audible and I love it.
Is your Apex coil whine free?I wouldn't say it's bad, I've had cards far worse. The only card I've had that didn't have any coil whine of any kind was a 1080Ti from Palit years ago.
To put a bit of context on the 4090 I have, if you're familiar with coil whine on PS5 consoles, they're far worse. I appreciate that the whine on PS5's is from the power supply but just using the noise a reference point.
I'm using a Define 7 XL, AX1600i and Z790 Apex.
I don’t actually know. I don’t believe there’s ever been noise from the motherboard, but where would the coil whine come from?Is your Apex coil whine free?
Thanks for coming back to me.I don’t actually know. I don’t believe there’s ever been noise from the motherboard, but where would the coil whine come from?
In normal use all I hear are the case fans, and the graphic card fans.
I would just stop my fans to try and listen to it to see if there is any noise from the apex.
Only thing I had heard about was severely bent boards so that’s all I was focused on when I first got it. And fortunately nothing major to note. Was as straight as any other board I’ve had. For the price it cost it should have re-enforcement like the extreme boards though.
But it seems that Zotac is using low quality fans and their motor makes noise independently from RPM, which would be a problem for my silent build.My 3080 Ti FE had it at certain fps, like 500fps when in the menu of a game, otherwise it was fine. 2070 Super had it in games when the fps was in the low range, the 4090 Zotac Trinity does not have it to any degree that it's noticed.
The quickest way to test it is the little 3D test in GPU-Z.
If the PNY I am getting has too much CW I might try Zotac next. Any chance you could post audio or video recording of different fan speeds of your Zotac while keeping other case cooling at min RPM?My build is silent and I have no problems with fan noise from Zotac? It's quieter than my 3080 Ti FE at the same RPMs.
That would be great and I would do the same with PNY when it arrives.
Thanks
EDIT: How is coil whine on yours Zotac?
I was so fixated on PNY alleged CW free operation, and then also after reading in this thread horror stories about MSI Suprim X I let me pass by some great deals for Suprim X and now the prices went crazy (300 more euros suddenly for Suprim X) so PNY it is.my msi supreme x and ventus 4090 models both have zero coil while, the last card i had powercolor 6900xtx was horrendous, just luck of a draw i guess
Thank you very much for taking time to make those vids for me and others. I will watch them nowSure here are some videos:
In-game VBIOS in quiet mode:
In-game VBIOS in normal mode:
The idle fan speed when you do something 3D in the desktop causing the fans to come on at a low idle rpm for a few mins or when you boot into Windows and the fans haven't entered the stop mode yet:
As for coil whine, not even noticed it tbh whereas I would notice it on the 3080 Ti FE!
For ref I keep it in quiet mode all the time, the other case fans etc don't spool faster than 500rpm until the CPU reaches 65 degrees, which is very rare nowadays due to games all being GPU bound at the settings I play.
Ok I have watched them now. Thanks again. I can see why people say that motors are not the greatest as if I am not mistaken as to what I hear those can be clearly heard making noise but in general especially when in game under load with quiet bios it seems very reasonable. Are you gaming in 4k?Sure here are some videos:
You can set whatever fan curve you desire through MSI Afterburner or Zotac's Firestorm utility, as well as switch the VBIOS mode using Firestorm.Ok I have watched them now. Thanks again. I can see why people say that motors are not the greatest as if I am not mistaken as to what I hear those can be clearly heard making noise but in general especially when in game under load with quiet bios it seems very reasonable. Are you gaming in 4k?
I was not that impressed with desktop performance but I am guessing that you are using GPU in zero fan mode and you let it spin when needed? Have you tried setting a custom curve for it instead?
I normally don't use 0 fan mode on my GPUs but instead set GPU fans to highest inaudible setting and adjust curve from there. So I leave GPU on highest inaudible fan RPM until 55-60C and after that I let it ramp up to 100% at 80C or something like it.
Is there an RPM that can be set like this? Inaudible but spinning and keeping GPU happy on desktop work? If so what % or RPM is it? If you could explore that for us. It would be also good to hear a recording of it to see if motor is inaudible when set like this.
Many thanks!
honestly speaking, i prefer my smaller MSI ventus, the heatsink itself is 2 slots, and only takes 4 screws to remove the shroud with fans. I have 2 x 120mm noctuas on it and an undervault, i dont think i've seen temps higher than 62 degrees.I was so fixated on PNY alleged CW free operation, and then also after reading in this thread horror stories about MSI Suprim X I let me pass by some great deals for Suprim X and now the prices went crazy (300 more euros suddenly for Suprim X) so PNY it is.
If the prices were the same as 3-4 days ago I would probably cancel PNY and order Suprim X
Let's how this PNY performs acoustically both fan and CW wise.
I can hear the coil whine in the second video quite clearlySure here are some videos:
