Sure, there is no hurryNope sorry dude, not had time. Will when time allows.
It's easy to translate, you need only your smarthphone and google translate: using your camera google will show you japanise text translated in englishIt's all in a language I can't read or understand, so no probably not.![]()
Nice. Thanks dude for the heads up!New AMD chipset drivers released.
I would like to think that's automatically done these days with a new exe.whats the best way of updating amd chipset drivers? i read some time back its best to uninstall the old ones first and then reinstall. is that right?
Looking into a 7950x3d will a MSI tomahawk x670 pair well?
Thanks for that.I've got one with my 7800x3d. Info on them seems sparse for some reason, maybe as they are new and "cheap" the mainsteam have ignored them infavour of chip killing expensive ASUS?
So far zero issues on mine, had it since day 1 7800x3d.
Think it only released semi-recently. I remember it being difficult to find in stock anywhere back when the 7950x3d first came out.I've got one with my 7800x3d. Info on them seems sparse for some reason, maybe as they are new and "cheap" the mainsteam have ignored them infavour of chip killing expensive ASUS?
I've seen quite a few random comments about it failing, but it doesn't seem to be entirely universal so probably some kind of silicon lottery? Some people were RMAing over it. Otherwise you have to try positive offsets.anyone else have issues with CoreCycler and AVX2/Small? my 7950x3d is failing at all stock (well, bios defaults on an X670E Hero), on Cores 8 & 10 (the two fastest, according to hwinfo and ryzen master, though RM calls them Cores 9 and 11).
thanks. yeah i've sent OcUK a ticket, will see what they say. bit disappointing, i feel i've had to do a lot of faff to (fail to) get this setup to work at fairly boring settings (i.e. just use my DDR6000 at its rated EXPO speeds, with entirely stock CPU settings). last time i built a system it was an 8700k...boot, turn on XMP, let it turn MCE on, done.I've seen quite a few random comments about it failing, but it doesn't seem to be entirely universal so probably some kind of silicon lottery? Some people were RMAing over it. Otherwise you have to try positive offsets.
Mine passes but I can't really push negative CO very far. Other instruction sets were stable a lot higher.
Be interesting to see how you get on with this. It should pass at stock settings. Hopefully you update!thanks. yeah i've sent OcUK a ticket, will see what they say. bit disappointing, i feel i've had to do a lot of faff to (fail to) get this setup to work at fairly boring settings (i.e. just use my DDR6000 at its rated EXPO speeds, with entirely stock CPU settings). last time i built a system it was an 8700k...boot, turn on XMP, let it turn MCE on, done.
Not I but I've not used the machine much.Has anyone noticed or had any performance dip since the new chipset release?
I was getting dips in gameplay last night quite badly in bf2042 and it was just after I updated the chipset and latest catalyst drivers. I'll give it another go this morning.Not I but I've not used the machine much.
Prolly the game than the hardwares software.I was getting dips in gameplay last night quite badly in bf2042 and it was just after I updated the chipset and latest catalyst drivers. I'll give it another go this morning.
