For some reason, I seem to have to buy a new snow foam lance every year.
I don't use them so much during the winter yet come the nice weather they'll either not work properly straight away or after a few uses stop working.
Like the solution doesn't get pulled into the head, or just doesn't foam up as well as before. I've tried taking them apart, soaking them in hot water and changing the internal hose. They all seem to just stop working.
More or less decided they're just yearly consumables but it is frustrating.
In winter/when the car is really dirty I give a spray of citrus apc wherever it's really dirty, leave for a minute or two, then go over with snow foam. I find it does help bring more dirt off than snow foam alone.
