Got some new wheels for my Taycan. I wasn't keen on the old wheels, and liked the 21 inch Taycan GTS wheels so I gradually bought a set one by one and got them redone in Porsche aurum gold.
For reference, these are the old wheels:
Pollen is the dust first lots of tree pollen now lots of grass pollen!!Had a bit of a nightmare trying to wash the Qashqai today - been getting this horrible dust film building up on the cars for 2-3 weeks now, hardly worth cleaning them it comes back so quickly. Pressure washing, Snow Foam, Armour All, resorted to hand washing with a sponge whatever I did as soon as it dried out a smeared around film of dust appeared. Only thing which would touch it was Showroom Shine but I was nearly out of that so had to use it sparingly so far from a ideal result. For want of a better way to put it was like anything water based wasn't "debonding" it from the surface even going over it 3 times with the pressure washer.
do you need to get headlight realigned if you dismantle them to clean lenses out ?And then I cleaned out my headlamps ahaaa!
Nope the alignment dial is not touched so the angle of alignment should not change. You can align the beam pattern on your driveway anyway, it's super easy really if you do accidnetally twist the knob on the back of the headlamp housing. You should not be touching the reflector/projector either! Just working around those core components. Also never touch the inside of the headlamp lens cover as they are specially coated. Even touching them with a clean cloth will create micro-marring patterns that can never be fixed. I made this mistake by accident when I first replaced the lenses as saw a bit of dust and instead of blowing it out, used a clothdo you need to get headlight realigned if you dismantle them to clean lenses out ?
I'd like to do mine (and perhaps try some compound with DAP) but, had that concern, plus that sealing rubbers (never been out) could be dilapidated
Had to order a new lens at £45 :/
Lame and strange. BMW still uses glass on MINIs.Yes, all modern BMW lenses are plastic, regulations I suspect.
You're right, it's plastic. Looks great for plastic.Are you sure? They seem to be plastic on ours?
