- 1 Jan 2003
- Derbyshire
I should really post a link if people want to try it
You do need to follow the install instructions otherwise the app will force close when you try to open it, but it's pretty straight forward and only involves making a folder and dropping config files in there and on first use opening GCam by pressing and holding the app to then load up the config you want to try. Then you good to go
XDA Gcam
If I find the time, I'll put some comparison shots up, but it's always interesting to hear what others think.
XDA Gcam
