- 9 Nov 2009
- Planet Earth
As per usual Digital SHilleries are attacking AMD , even when its faster than Nvidia. Oh and the ` review` didnt even bother with Intel cards.
I can't find any review of the RTX4060 from them?
Got pulled?I can't find any review of the RTX4060 from them?
Need to see more reviews with dlss3 in use. Jays preview with cyberpunk has me impressed with the tech. I was the sort of guy that would say no to any sort of upscaling but having used dlss2 first hand i have it enabled in every game i have that supports it on quality mode even if its locked on vsync at 60fps, dlss on just drops power consumption at that point lowering fan noise and heat.
But no one has shown what happens if dlss3 frame gen is enabled at as native 30fps to bring it up to 50+ fps, thats where it would be great, since i play with vsync on at 60fps i dont see the point in frame generation to just go above 60fps unless you have a high refresh monitor?
Maybe,but I can't believe in 2023,we are having newly released cards between £260~£400 still with only 8GB VRAM when VRAM prices have collapsed.Got pulled?
Wouldn't that be more of a software review, DLSS is basically software that tries to makeup for the shortcomings of hardware and it's not even supported in all games.Hardware unboxed seemed to be very biased, not even looking at dlss3 which is a feature i would be using with these cards.
Still its a 4050 in disguise
even jay says switch to amd![]()
Surely the opposite is the case?Need to see more reviews with dlss3 in use. Jays preview with cyberpunk has me impressed with the tech. I was the sort of guy that would say no to any sort of upscaling but having used dlss2 first hand i have it enabled in every game i have that supports it on quality mode even if its locked on vsync at 60fps, dlss on just drops power consumption at that point lowering fan noise and heat.
If its a software feature then it should work on cards like the gtx 780?Wouldn't that be more of a software review, DLSS is basically software that tries to makeup for the shortcomings of hardware and it's not even supported in all games.
What, why should it work on a GTX 780? That's like saying AVX-512 should work on a 486 or x86 should work on ARM.If its a software feature then it should work on cards like the gtx 780?
The reviews are about the hardware that is the RTX 4060, not about the software.
Not sure why you think there's a contradiction, i would say that maybe you should explain why but TBH I, like it seems a growing number of people, simply don't care enough any more about what Nvidia are releasing. At least before people cared enough to get annoyed/angry. Now as Linus said apathy has set in and that's a very dangerous position for Nvidia (and to a lesser extent AMD before all the hate) to find themselves in.Your posts seem to be contradicting each other?
I'm not sure it willLaughable GPU... But will sell in the thousands and they know it!
Maybe not to educated peopleI'm not sure it will
only to the uniformed i would thinkLaughable GPU... But will sell in the thousands and they know it!
