- 28 Nov 2011
Not sure. It looks like a smallish square/circle? Not really noticeable on light backgrounds, but is more visible on darker or grey backgrounds and when the screen is dimmer.That doesn't sound good, could it be screen burn or are you thinking some type of defect?
Edit: Found this image on Reddit. Ignore the arrows and all that stuff. That tiny circle/square dot up near the camera is in roughly the same area i can see mine. Although mine doesn't seem as bad as that?
Edit Two: Switched over to light mode and rang voicemail. Saw the proximity sensor that pops up. Like 4 little squares that make a square and it's slap bang where that mark is! So I've no idea, maybe it's always been there and i've only just noticed?
Reddit - Dive into anything
