K makes sense. Why would it be recommending so much higher though?The pressure recommendation in iDrive is adjusted for tyre temperature but the pressure on the door sticker is for a cold tyre.
I don't know - I have the same thing with mine and I still don't really understand it yet![]()
Hindsight is a wonderful thing.Buy an AUC car next time? Sorry not much help.
Nah, anything I buy ends up a lemon.. its guna be fine.Wasn't unexpected though was it![]()
doing it on the warranty you had, is out ? jut the hassle of the logistics.Anyway, the steering racks thrust bearing is worn
Warranty? Oh that 3rd party nonsense i was given? It's classified as "wear and tear"... so no go.doing it on the warranty you had, is out ? jut the hassle of the logistics.
Could you let me know what they say about it (if anything) please?![]()
Mine has gone in today, just seen on the 'online tracker' notes
"DAB reception ok, no faults in system, 12volt cigar chargers can cut dab reception"
missed this from nearly a week ago. I'm getting mine done soon at a ZF agent up here in Glasgow. 2015 428i with the 8 speed auto, 46,000 miles. £350+VAT so £420.Has anyone had their transmission fluid flushed and renewed on the 8spd auto? Be it the ZF or Aisin unit.
Is it worth doing as preventative maintenance after 7 years and 40K miles?
I agree, but on the VAG cars we have the reception is way better, and also was on my 2012 ford mondeo!I don't think there is anything wrong with it - it's just not very good.
Mine is the same on multiple cars.
I had a look through all the tyre settings, didn't change anything and when I came out the menu it started calibrating them again and recommended a lower pressure. Not sure why, was similar weather conditions both times. Least I don't get the notification now.I don't know - I have the same thing with mine and I still don't really understand it yet![]()
Just set them to what the cold pressures are meant to be and don't worry about it. I set mine to cold pressures but my car doesn't give me live updates.I had a look through all the tyre settings, didn't change anything and when I came out the menu it started calibrating them again and recommended a lower pressure. Not sure why, was similar weather conditions both times. Least I don't get the notification now.
