My expectationsIt's a TDP capped APU running windows, it's performing well, but it's nowhere near a 1070/1080, your expectations are a little high.
Wonder if it's really worth £700 then? Vs a second hand steam deck for £400? I do plan to game out and about but also plan to utilise the 4080 at 1080 by streaming the PC.
Has anyone attempted to installed SteamOS / ArchLinux on the ROG Ally?
Whats peoples thoughts on these... Had a few requests in for hardware mods on them (specifically a doubling of internal ram) so am considering buying one to mod before I mod anybody elses.
Just to highlight the memory usage point, playing about with my daughters AOKZOE A1 Pro now I have her set up like @oweneades so it can be her desktop etc. via a TB dock, I was just seeing what it could do on her monitor, only a 1080p screen, just APU, no fancy eGPU for us.![]()
I whacked on Horizon Zero dawn @ 1080 in Ultimate settings no scaling etc, so full textures, full rendering etc, the system is using 23.4Gb to do this (configured as 6Gb reserved for iGPU, hence the weird 25.7Gb sys RAM, but of course here it is still using more sys RAM for graphics and why RAM usage is high) it runs silky smooth albeit at only a 33fps average but that's max settings, it's not bad considering, you wouldn't necessarily play it like that, you'd knock on FSR to double the frame rate but even that in max settings FSR quality its only saving a couple of Gb.
So the extra RAM can definitely get used well, 32Gb is not a silly amount for iGPU usage. 16Gb is a bit stingy when you have no dedicated VRAM as you end up paging to disk or having to run much lower settings, though seems less of an issue paging these days with super fast NVMe etc, not like the old days of spinners and of course on a small screen when mobile can you really see the extra texture detail.....not really, even so, nice to have the extra.
)These chipsets are awesome, you could just do it on the internal screen to replicate, the Ally would be superior with the higher TDPs available and the seemingly better z1 chip but don't think its going to do Ultimate well with 16Gb.
Going to this reminds me of when I shifted from intel iGPUs back in the day to AMDs first APU, that too felt next level, a proper upgrade unlike the poor shifts from 2400g to any other xxxxg iGPUs pre 7xxx. ( I've had everyone mind you.)
Lets hope future ones bring even more balance.
I thought the 7840U turned out to be slightly better than the Z1 Extreme?These chipsets are awesome, you could just do it on the internal screen to replicate, the Ally would be superior with the higher TDPs available and the seemingly better z1 chip but don't think its going to do Ultimate well with 16Gb.
I have little opportunity to play with it
I think it was the right choice. I hadn’t really considered mobile PC gaming beyond a laptop until I saw the steam deck sale. I added a 512 to my basket to try it and then checkout failed and they were gone! I saw the Ally, decided to grab one, almost double the price of the sale units, but, to be free from steamOS and to be able to do whatever I want is great. Plus better screen, gpu etc, smaller and more portable.After failing to get a steam deck during the sale, I ended up getting an Ally instead. Totally worth it in my opinion
HZD I thought it would run well being an older ps4 game. But it struggles. On high it chugs at 1080 at about 30 frames. To get a smooth experience it has to be 720 on high, then you can hit 50-60. I would have thought it would have done better here.
