None of the 40 series generate too much heat or run noisy though - Very efficient cards and in general will run at lower wattage than specced out of the box when gaming anyway. My 4090 runs cooler, quieter and draws less power than the 3080 Ti FE it replaced, for example.
The mistake you made was getting an AMD card, because now your perspective is that all high end cards are noisy heat monsters that eat power.
