- 22 Nov 2020
Of course. EVO non-XL.Lian Li cube case?
For people running MBA 7900xtx's how have your temps been this summer?
it was one of my initial concerns when I purchased mine back at launch, But I've actually been pleasantly surprised with how well my card has kept within the same kind of temperature range without really throttling, Even though I have not changed the fan curves.
Compared to that my MBA XT on air is so hot and that’s also undervolted to 990mv! 79-81C hotspot and core at 57-60Cbeen running my new mba xtx under water most of the day, idle temps around 23-26c and load is 38c core and 58c hotspot, super cool and not much coil whine, clocks easy getting into high 2900mhz region and ram at 2600mhz with fast timing, rreally happy so far XD
I’ve had to raise my voltage to 1010mv as just had my first crash on COD lol. Still same temps though.been playing around with volatges all day and so far card is at 1099mv, your xt is right on the money if on air your hotspot temp looks hot but anything under 90 is great, your core temp is also pretty low tbh![]()
Do gpu cores deteriorate with time needing more voltage to sustain clocks?1010mv does seem to be a agressive curve but then again all cards are diffrent, golden rule of thumb is find the lowest voltage that is stable across a variaty of games, but as time goes on dont be suprised if you need to up the voltages to maintain stability
Oh dear hadn’t realised undervolting degrades cores but as you say it doesn’t really matter!they will eventually if undervolting the silicone will degrade slightly but not enough to cause problems, cards need to be a grand old age before problems start to happen but at that stage a new gen should be on your shopping list
Gah I want to get mine under water too, those temps sound lovely.been running my new mba xtx under water most of the day, idle temps around 23-26c and load is 38c core and 58c hotspot, super cool and not much coil whine, clocks easy getting into high 2900mhz region and ram at 2600mhz with fast timing, really happy so far XD
ooooohhh lovely can you post your settings please, would love to compare them to mine.![]()
just had a short time in destiny2 and recorded the above, front end clock above 3100mhz, watercooling is the way to go![]()
Thanks, that voltage is low very impressive.
