- 23 Dec 2022
- London
I've gone for the sapphire pulse. Sell my MSI supreme 3080. Will be a good upgrade.
I love mine its a beast.
I actually prefer the looks of the Pulse.The Pulse is basically a Nitro+, but with a lower power limit and no RGB. It uses the same PCB and I personally love the black and red theme on the shroud.
Yeah I can see why some might prefer it, the design is slick. I remember @Techen's 6900 XT Pulse and that looked lovely too and was quiet as a mouse, bar the fact it was faulty.I actually prefer the looks of the Pulse.
If only I still had my X570 Aqua.![]()
Which RX 7900 XTX to BUY and AVOID?! | 15 Cards Compared! Asus, Asrock, Sapphire, Powercolor, XFX
Which is THE BEST RX 7900 XTX? Let's compare the VRMs, Power Limits and Cooling performance of these different models! Join the O!verclock Club to support me...www.youtube.com
Not that many details but the TLDR are all the PCB are high quality and nothing major to be concerned about on any of them. The Asrock Aqua card has the highest power limit with a bios update and the XFX Merc has the noisiest and worst cooler out of the AIB partner cards.
Will check the bios later but pretty sure it’s enabled. I installed Windows and had all the drivers ready to install on a usb drive so they got installed pretty quickly after first boot.That is not normal at all. Have you overclocked either of the cards at all ? They are quite tricky to get a stable OC and if you do not do it right then you will experience exactly what you are seeing.
Oh one more thing that may be the issue. You say you updated the chipset drivers , did it have the normal 7000 series chipset drivers before you updated for the 7800X3D chipset drivers ? If this is the case it is a known issue and you have to do a clean instal of windows then instal the 7800X3D chipset drivers.
Edit- Have you enabled SAM in the BIOS ?
- Enter the System BIOS.
- Navigate to Advanced Settings or Advanced menu.
- Enable “Above 4G Decoding” and “Re-Size BAR Support”
Could look like a dead ferret for all I care tbh, solid side panel ftwMe too, the nitro is a bit OTT and bulky for me. The pulse is slick.
But I do like something big and thicc to hold before it goes in![]()
Amateurs...They're getting so big and thicc these days some people are struggling or accommodate them or struggle to insert them...
Jeez that escalated![]()
Which one did you get? One of the Pulses?You cant faulty OcUK free shipping. Ordered Late friday afternoon, and delivered today.
Now its been a while since I had a AMD GPU. Can someone point me in the direction of setting it up, undervolting etc.
There's an Auto Undervolt feature in AMD software > Performance > Tuning menu. https://www.amd.com/en/support/kb/faq/dh3-020You cant faulty OcUK free shipping. Ordered Late friday afternoon, and delivered today.
Been awhile for me as well, last amd cards we had were 5850s, 5870, 7970.You cant faulty OcUK free shipping. Ordered Late friday afternoon, and delivered today.
