Winrar user here as well as I prefer it![]()
Winrar is said to have faster unpacking than compressing, whereas 7zip has faster/better compressing than unpacking.
I tend to unzip more often these days so maybe it's worth the change. And then I unpack files WAHEY!
I will consider joining the Winrar gang once again.
Edit*
I have done some testing.
Downloaded the current version of Davinci Resolve which is 2.45GB. Needed to update anyway so two birds one stone.
Anyway,
Windows explorer extraction: 18.87 seconds
7-Zip: 8.5 seconds
Winrar: 11.15 seconds
So 7-zip wins at unzipping too.
Winrar uninstalled![]()
As far as I know winrar dev has also ceased, so 7zip wins are only get to get better moving forward.
Still gets updated quite regularly.As far as I know winrar dev has also ceased, so 7zip wins are only get to get better moving forward.
Ok, regardless I consider it dead anyway.Still gets updated quite regularly.
There must be a switch to add to the exe shortcut to trigger a run without using GPU decompression or any DS, just transfers the same data the old way. Someone will know![]()
Usage
BulkLoadDemo [-dir <directory>] [-model <filename>] [-gpu-decompression {0|1}] [-debug {0|1}]
The demo can operate in one of three modes:
GPU decompression is enabled by default, but it can be explicitly enabled/disabled using the -gpu-decompression argument.
- Default: by default, any .marc files in the same directory as the executable are loaded. Multiple instances of these are loaded in order to ensure that there's enough work to do.
- Single Model: The -model command-line argument can be used to specify a single .marc file to load. This mode is mostly useful for debugging a single model.
- Directory: The -dir command-line argument can specify a directory. All .marc files within this directory are candidates for loading.
The D3D12 debug layer can be explicitly enabled or disabled using the -debug argument.
Close the window, or press Escape, to exit the demo.
It's been confirmed that R&C has DLAA so that's how I'll be playing itThis is great news for those at 1440p, you'll get over 100fps with DLSS off lol if you have a 4090, or use DLDSR at 4K to get the best image quality along with the best framerate.
