Just some numbers to put the 75% into context. If you run the 13900k with no power limits, it hits 41.5-42k score on CBR23. So 75% on top is 70k+.
The 8P core on Alderlake can get around 20k. The 8P cores on RPL (this one I haven't tested, it's an estimation) can at most get what, 22-24k. The 16 ecores contribute another 20k. So even if the 15900k is 16P+16E core configuration, it's not hitting over 70k. 60k sounds more realistic. If they keep the same number of cores, so 8+16, no way in hell it's hitting anywhere near 70k. That would mean that the P cores would need to be twice as fast - which I find impossible.
