No to all.Do you have the AMD metrics overlay enabled, or AMD instant replay (in ReLive settings)? Or any of the iChill or other settings on?
I did notice my HOTAS throttle was playing up (if I connect it to the wrong USB port it doesn't register properly and blips in and out, so I swapped it to the correct USB port.
Then I did another run and got 23111 with CPU score 12039 so back close to where I was before. Perhaps it was that USB port issue taking up some CPU headroom.
What undervolt is reasonable? Stock is 1100 mV, Ive been testing 1075 mV, can I go lower?
