Did the windows inbuilt memory test and it was ok nothing fault is that a good test I don't know?6400 ram speed might be a little abitious tbh ( unless its with really loose timings ) - Have you tested that for stability ?
Just because it boots to Windows with EXPO doesn't mean its stable.
I might at this point just put it all back to standard and run the ram at expo settings 6000....
