Doesn't the mere act of connecting and disconnecting a pump/gauge mean that you lose a little bit of pressure each time? How do you take that into account?Usually each tyre no more than 0.5 PSI down which requires five pumps on the foot pump to bring them up and sometimes no extra air is needed as they are still what I set them to two week’s previously. Occasionally if it’s got warmer over the two weeks they go up 0.5 PSI and I have to let a little out.
It’s not a problem when removing the pump as I check with the gauge straight after. I find as long as you apply firm pressure onto the valve with the gauge you get an instant reading and lose very little air. If you’re a bit loose with the connection onto the valve with the gauge you can lose air.Doesn't the mere act of connecting and disconnecting a pump/gauge mean that you lose a little bit of pressure each time? How do you take that into account?
Where else should one keep an air pump?(which for some reason she insists keeping in the boot of her car)
Lithium battery powered inflators rock!
The Mrs has a Ring 12v DC powered inflator (which for some reason she insists keeping in the boot of her car) which you hook up to the car's power supply, but it's a faff extending the cable and passing it through the doors either side. I got in the habit of using my cycle track pump instead!
This new one I bought is an Aldi special and was £12 excluding the battery and charger, but I had that anyway for the gardening tools. It's shaped like a cordless drill, but instead of a drill chuck a short length (admittedly very short) of airline with a shraeder inflator valve on the end.
Simply dial in your chosen pressure (bar or psi) connect the line and pull the trigger until the unit cuts out when the desired pressure is reached.
I actually enjoy using it!
Yes I am sad.
I've got the Ring one, keep it in the boot in case of emergencies
when i get my new car , ill be getting the cordless version
and thanks for the last thread on "which inflator" as someone pointed out to me you get get a quick release adaptor to fit on the ring (screw) so its quicker to get on and off now
Oh link please?
This popped up on my youtube recommended yesterday as well.
Thanks, ordered.![]()
Tyre Valve Air Chuck Inflator Pump Connector Adapter Brass Clip on valve UK | eBay UK
Features: 1x High Quality Brass adapter. 1x Air pump Adapter. MADE OF HIGH QUALITY BRASS! Material: Brass.www.ebay.co.uk
8mm i believe
It popped up in the OP tooThis popped up on my youtube recommended yesterday as well.
FFS - I never even noticed, I was mainly replying to the replies!It popped up in the OP too![]()
Anyone got a link to a decent battery tyre inflator? I've been looking for a decent one since i found out the cheap AA one i've got is about 5 PSI off lol.
