Pic: Your desk...RIGHT NOW
Gradually turning my desk into a rainforest.
Need to shift the Schismatoglottis further left. Might need a custom printed support
https://i.~ibb.co~/nzBfpMb/PXL-20230827-170311515.jpg
It's messy underneath with router and HP microserver. It's awkward with a corner but if I put the monitor on the right, it has a window facing it so glare is an issue.
I'd like a mat for keyboard and mouse but again, it's a corner.. need help!
Personally I'd shunt all the hardware out of the corner, over to the side, and nestle the monitor right into that corner with a decent mat spread in front of it for the desktop. Gives you space for your legs if you can shift the stuff under the desk.
Could the soundbar speaker be hung from the shelf above?
What is that above the mac? A light to make you look nice for Only Fans? I've never seen these before.
Exactly that, yes :) ;)
No but seriously, the majority of my job is on video calls, now that face to face meets are restricted, so I use the light to keep the white balance and lighting controlled for them.
