I would payYou not think of LtMatt optimisation services as a sideline?
it would be very stressful for the guy I bet. This is why he does not like this.I would pay
I would pay
Can anyone (looking at you @LtMatt ) tell me what a "safe" voltage is for CPU vddio/MC on a 7800x3d..? Little concerned mine is tad too high when it was on auto
Cheers for the reply. I as worry as mine seemed to be pretty high. Had memory at 1.4v but the CPU vddio/MC was reporting at 1.48v! So I stuck it low to something like 1.3v and it wouldn't play ball at all..Researched this a while back during the vsoc debacle. VDDIO is intended to be the same as your memory voltage. Mine seems to be 1.35 with 1.4v memory and has no issues, but there's no reason to worry if you're in that standard operating range. Some people reported problems when trying to lower it (which would be typical if you have voltages that are meant to be equal but are instead presenting a gradient).
It shouldn't be thought of as a thing that has the same limit as the vsoc.
1.35 will likely be absolutely fine but there's no reason to worry about 1.4.Cheers for the reply. I as worry as mine seemed to be pretty high. Had memory at 1.4v but the CPU vddio/MC was reporting at 1.48v! So I stuck it low to something like 1.3v and it wouldn't play ball at all..
oh no againThank you, I still don’t understand why I was suspended but there we go.![]()
With any overclocking on AMD or Intel, hell to that. One bench for me and then roll the dice.The YCruncher 1-7-0 test is not sufficient to get Curve Optimiser stable. It is only one tool that can be used. Corecycler and OCCT are also needed due to the per core testing at different modes SSE,AVX2 etc for long periods of time. Then there is SHA3 which if you want complete stability in my opinion you must also pass.
There is no 1 test that you can use to get Curve Optimiser stable. Even after everything I have mention there is still idle stability which can happen at any time (even during important work you may not have saved).
7800x3d and 7950x3d are great CPU’s but are an absolutely nightmare to tune for very little gains especially when gaming.
Leave stock and enjoy.
I understand why you do things this way. It makes life much easier. And is honestly a the best way. Some people play benchmarks that is their game, and if they like this I’m happy. I’d much prefer to be actually gaming instead of running Prime 95 AVX512 small FFT for hours and hours.With any overclocking on AMD or Intel, hell to that. One bench for me and then roll the dice.
Yup 100%I say leave it alone and play your games
Decided to set the times manually rather than EXPO, found a setting in bios of my board for 2 x 32gb 6400 Samsungs, used that but set the frequency to 6000mhz and its been rock solid ever since, its even lowered the timings to what expo was using from cas 40 to 38, weirdYesterday was having all sorts of issues, left pc for a while and it went to sleep wouldnt wake up, hard powered it down and was stuck at the yellow light on board (memory related I believe) and refused to boot, had to eventually clear CMOS to get it to boot, left ram at stock and its been perfect ever since, saw that AMD only officially guarantee 5200mhz so maybe my chip isnt a good one or the ram isnt upto spec?
And what is even weirder is that i have reduced latency and increased ram speed from 44 and 5200mhz and ive lost 20fps in warzone?Decided to set the times manually rather than EXPO, found a setting in bios of my board for 2 x 32gb 6400 Samsungs, used that but set the frequency to 6000mhz and its been rock solid ever since, its even lowered the timings to what expo was using from cas 40 to 38, weird
