- 30 Jun 2006
Thanks for the tips. I ended up with the Meshroom S fossil grey version, love the build quality of the case and modular options.Yes Its possible to mount a SFX Power Supply at bottom behind the motherboard tray IN SSUPD MeshLicious,
could just screw through the panel holes with the PSU screws to hold it in place, not sure on the vented holes of the PSU & the holes on the Case
Also the position of the power switch & power cable input have to be just right. if not some Modding.
Possible if your Using CPU IGPU Graphics or use the horizontal position for a graphics card that 180mm to 245mm long If not using a front radiator with fans
Mod the SSD/HDD trays at front bottom
