Needs a good western man to take her in hand.
Your regular reminder that Russian makeup trends are still stuck in the 1980s.
Hopefully the first videos that come out featuring Challenger 2's are one where it's kicking commie backsides and not a stuck lump of metal with the tracks blown off.That's why challenger 2'a haven't been seen until now
Ukraine has sent in its 82nd brigade, which has been waiting in reserve and this brigade is equipped with the challengers and also US Strykers so we now for the first time see both of these vehicles
We've got to be realistic, it's bound to happen. They're not invincible, and they're there to be used.Hopefully the first videos that come out featuring Challenger 2's are one where it's kicking commie backsides and not a stuck lump of metal with the tracks blown off.
Bottom line is this war has taught the arms industry a lot. Drones are king now and the information they are getting is how to deal with them and how to protect armour from them.They could have created a lot of jobs making them in the UK, as always though we never learn and we'll probably learn the hard way for only having enough for half the compliment of tanks
Possibly, the detonation will be on impact with the cage and take a lot of momentum away from the penetration power they have.Would that cage help against a Lancet?
The old idea of surviving a direct shot from an opposing tank to the front seems obsolete.I would also assume they will have to buff the armour on top of the tanks as they cant afford any weak spots.
That's all the evidence we need of Russian stock piles running low, if they are firing missiles at Ukraine that were just manufactured instead of firing old stuff because the old stuff is gone
The west has already pledged billions to rebuild Ukraine, those billions mean contracts.And while that sounds good, it's actually a vague statement because it doesn't state any actual goals for when support will stop and could mean that support can end at any time or it also could mean USA will continue to help Ukraine for the next 20 years (that doesn't mean 20 years of war but could be 20 years of nation building support to get them ready for joining the EU and NATO)
You're more likely to be taken out by a mine, artillery or someone flying a cheap Chinese drone with a hand grenade duct taped onto it into your open hatch.
Just waiting for a armoured vehicle “drone carrier” that launches drones and hands them out to operators by flying them to position.
its a nano second but it should be in thousands of pieces spread over the entire tank rather than one penetrating spot.
