AMD probably wouldn’t allow it until they can develop their own inferior version.
I thought fsr was built into it?AMD aren't blocking DLSS, they game doesn't come with any vendors upscaling tech, including FSR, as usual it was all a whole load of hot air click bait.
Besides that it looks like FSR3 might actually be as good if not better than DLSS3.
Spoke to the retailed (where you might buy an FE card), apparently when I bought my CPU in July the promotion wasn't active. Boo.You get a code on your invoice, if the qualifying item was eligible for the game at the time of purchase. You then go to AMD rewards website, sign up or login and redeem the code from your invoice. AMD rewards will then ask you to link your steam account and you will have the game added to your library.
So far as i can tell, and i have been out of the loop for a few days... SF has FSR3 'for the XBox Series X' but not in the PC version, not yet at least, and AMD have come out and said Nvidia are free to add DLSS to SF.
Last i knew someone checked the install files and found no DLSS, XeSS or FSR, i haven't seen anyone playing in early access saying it has any of those 3 techs in the PC version.
From what little I have seen so far this is turning out to be better than I expected. Did not expect this level of polish.
Even more excited now![]()
I've read multiple times it has FSR2. Even seen a screenie with it?
Its not FSR3, which is a shame, hopefully they just need more time to put it in, people on older AMD and Nvidia GPU's will get to use it, it looks like they will need it....
32/39 1440P Ultra with a 6700XT?????????![]()
Starfield PC Hardware and Settings Review
Starfield is a gorgeous game but requires some heavy duty PC hardware to get good performance. Having gone through the first few missions of Bethesda's Star...www.youtube.com
Recommended hardware tested:
The CPU makes a big difference! With a better CPU,you can get better FPS at 1440p than at 1080p!
imgur.com
Discover the magic of the internet at Imgur, a community powered entertainment destination. Lift your spirits with funny jokes, trending memes, entertaining gifs, inspiring stories, viral videos, and so much more from users.imgur.com
32/39 1440P with a 6700XT?????????
My poor RTX 2070 Super
GIB RX 7800XT.
Also look at the CPU bottleneck. I kept telling people in the GPU section who were going on about upscaling and I said in cities the game were going to be CPU heavy.
Yeah i see that, you were right
I'm not worried about that, 5Ghz 5800X with 3800MT/s RAM, its not the latest and greatest these days but still a monster gaming CPU.
I don't have an amazing CPU but I'm not toooo worried.
I am not so sure. Look at the Ryzen 5 5600X and Ryzen 5 7600X figures above!
Well you do because you are on Zen4.
Installed it now again and can confirm you can jump from space (another ship that lets you be outside) all the way down to a planet and using the jetpack to slow down the fall right at the bottom. Will need some healthy supply of life support fuel thoughOk fair enoughwhat use is skydiving from 100KM altitude without a parachute anyway, but dropping your APC or Tank out the back of a C2 above a low mavity moon, that's fun...
Being confined to a few square KM of a designated LZ, you have to admit that is a bit lame.
What difference does that make? Genuinely don't know lol.
