 - 9 Nov 2009
 - Planet Earth
As usual the UK gets shafted. Looking at Newegg and some other retailers in Europe there is stock and more models too,especially at near RRP.
calm down, eat less sugar or at least don't stick it up your nose. I DGAF which multi billion corporation makes a product that gives me 60 FPS when gaming, but the 7800XT has a strong argument for it.AMD fanboi
Just seen that if you go to the actual terms on AMD site, it is mentioned.Probably not updated, in the keynote/launch they mentioned it would be bundled with Starfield.
The ones worth buying are over £600, CAT.I don't think the RTX4060TI is comparable as its terrible. The RX7800XT is an RTX4070 competitor for nearly the same streetprice,so the RTX4070 would be no better.
But it seems some retailers are bundling Starfield with it(OcUK shows no game bundled),so its better value than both for now....which is not hard.
whats up wth OCUK stock and pricing ?
https://www.techpowerup.com/review/powercolor-radeon-rx-7800-xt-hellhound/41.htmlThe ones worth buying are over £600, CAT.![]()
Oh no not another captain hindsight!The 6950xt at £549 a few months ago was a much better buy!
Seems pretty good to me if you were searching around.
Ncice card, 12% performance gain from overclocking, matches a 4070Ti.....
				Bit of luck it'll be a £350/360 in a couple of months...The 7700XT could have been a real hero card but not at its current pricing.
The power draw is a bit of an eye opener espeically when you put it up against it's competition the RTX 4070. Whatever happened to RDNA 3 being 50% more efficient per watt?
