Reading the notes ir says AFTER THAT.. so sounds like it suppose to be in upcoming updates ? To be fair, i not started the games since the update though, so if the FOV slider is already there, then fine, I'm wrong !![]()
(teach me for ready instead of working)Reading the notes ir says AFTER THAT.. so sounds like it suppose to be in upcoming updates ? To be fair, i not started the games since the update though, so if the FOV slider is already there, then fine, I'm wrong !![]()
You can configure various settings for this mod by starting the game once then editing the config.json file in the game directory.
An explanation of the settings is provided below:
// DLSS mode to use. Since the game uses dynamic resolution,
// this will not affect image quality outside of changing the used preset.
// Only relevant for people with custom DLSSTweaks/profile setups, others should use the preset setting.
"dlssMode": "MaxPerformance",
// DLSS preset to use.
// "Default" selects the preset based on the "dlssMode" setting,
// otherwise this should be set to the desired preset letter. (A-F)
"dlssPreset": "Default",
// If frame generation should be enabled or disabled.
"enableFrameGeneration": true,
// If NIS should be used for a sharpening pass.
// Turn off if you are using ReShade with CAS or another sharpening pass.
"enableNisSharpening": true,
// Used to set a FPS cap through reflex. 0 means no frame cap.
"reflexFpsCap": 0,
// Reflex mode to use. Valid options: LowLatency, LowLatencyWithBoost
"reflexMode": "LowLatencyWithBoost",
// If reflex sleep should be turned on or off. Leave on unless you know what you're doing.
"enableReflexSleep": true,
// If the mod should be enabled or not.
"enabled": true,
// If dynamic resolution is enabled in game. Turn this off if you are not using it ingame, leave it on otherwise.
"dynamicResolutionEnabled": true,
// If over-the-air (OTA) updates should be enabled for Streamline (DLSS/DLSSG) components. Defaults to false.
"enableStreamlineOta": false,
// Do not modify.
"version": 6
Cant even look at Nexus Mods at work, there's titty mods already!
Pretty sure you can filter NSFW. Actually, pretty sure you have to enable it to see.
Maybe some of it wasn't flagged, im not even logged in.
Do you guys not have phones?Cant even look at Nexus Mods at work, there's titty mods already!
Thank's got to give that a go.This is a great mod:
BetterHUD - Enhanced Player Healthbar and Boostbar Patch - Scanner Encumbrance Display With Time Patch
Simple patch to add Enhanced Player Healthbar+Boostbar (WYOR, BYOR, GYOR) colors compatibility with BetterHUD v0.1.0 sneak peek. Not compatible with large fonts AFAIK, too lazy to figure it out. Now swww.nexusmods.com
Love that you can see what your encumbrance is when scanning, and like the enhanced health and boost bars.
Installed using Vortex.
Inventory mod stopped working for my friends gamepass version after update but didn't effect me on steam.
