Not sure if you can buy MBA off the AMD EU store, you can add to basket and shows sterling price.
Why the MBA is particular?
It is a 100% guarantee to fit in my case.Why the MBA is particular?
Give me a call when it's £470 for the 4070Ti.A £40 reduction isn't exactly setting the world on fire IMO.
Give me a call when it's less than £470.
**** it, I'll pre-order the nitro. Cannot be bothered to change the slot mode on the T1, major hassle. I do not like massive gaps between the panel and GPU, want something that just leaves enough.I'll need to wait and see what waterblocks get released so I can fit on in mine.
I can't see the 7800 XT at RRP anywhere in the UK unless I do not know how to look, which is entirely possible.
Give me a call when it's £470 for the 4070Ti.![]()
It (Sapphire Pulse) can be had for £489, which is £10 above RRP. You could buy it on launch day for £479.I can't see the 7800 XT at RRP anywhere in the UK unless I do not know how to look, which is entirely possible.
It is not in stock right now though.It (Sapphire Pulse) can be had for £489, which is £10 above RRP. You could buy it on launch day for £479.
That's correct.It is not in stock right now though.
I'll be waiting regardless as I dislike pre-order with an ETA. I need to schedule deliveries for the weekend.That's because you don't know the RRP for anything in the UK, is the RRP plus the vendor gouge on top. Pre-gouged for convenience!
I'd wait a month or so, stock will be back in and the price will slowly come down, they're drip feeding stock in because they've still got 6000 cards to shift and no-one is buying.
This GPU has caught my eye,
SAPPHIRE NITRO+ AMD Radeon™ RX 7800 XT Gaming Graphics Card with 16GB GDDR6, AMD RDNA™ 3 architecture
Order SAPPHIRE NITRO+ AMD Radeon™ RX 7800 XT Gaming Graphics Card with 16GB GDDR6, AMD RDNA™ 3 architecture now online and benefit from fast delivery.www.overclockers.co.uk
but I need to check my case dimensions. If the VRM fan on mobo will be hindered and I believe as it takes 3 slots I need to look at that angle of things , too.
Thanks for plugging the measurements. Appreciated. I'll do my homework tomorrow when totally soberYes, Sapphire are the go to brand for AMD. The Nitro's are very well built chonky cards, but make sure it will fit, alternatively the Pulse model is 2.5 slots and bit smaller all around. Pulse's a bit cheaper as well. I usualky but the Nitro but i'd happily buy the Pulse as well.
All the relevant measurements are included if you need them.
NITRO+ AMD Radeon™ RX 7800 XT 16GB
Up to 2565 MHz, 16GB/256 bit DDR6. 19.5 Gbps Effectivewww.sapphiretech.com
PULSE AMD Radeon™ RX 7800 XT 16GB
BOOST CLOCK Up to 2430 MHz, 16GB/256 bit DDR6. 19.5Gbps Effectivewww.sapphiretech.com
Measurements look spot on. Nitro+ will most like make my PCIEX16_2 non usable, but don't think I really care about that. The pulse would likely mean I'd still have that option open to me.
I've pretty much stopped subbing to any of the major tech journies. They are almost all of them full of BS at this point. Drawing conclusions from data that makes no sense to any person with a rational thought pattern. Sure, there are certain things that weigh more to one person then another but it is usually not portrayed like that but instead as a one dimensional fact of life with no nuance, as if RT is important to every single person on the planet. But I think that as a lot of people are getting fed up with BS in general(whole world situation going to hell in a hand basket due to certain interests) these YTbers, if they continue this clown show, might end up feeling the sting on their ad revenue.Its difficult not to and i don't think it is their goal to make the 4070 look better than it is, tho being dismissive of cheaper 7800XT's just because they are out of stock and then comparing the more expensive ones to the cheapest 4070 is IMO disingenuous, these GPU's have been out for days and are selling very well, they are in and out of stock from one day to the next and they just happened to be looking at price comparisons when all the MSRP ones were out of stock everywhere? come on Steve... I think you're just annoyed that you can't say they are over priced, its like when Steve says the 7700XT is overpriced and then says of the 4060Ti you can't compare the 7700XT to it because it an anomaly, come the #### off it Steve its 35% faster than the card its replaced and 6% cheaper, its not over priced, the 4070 isn't a bad price and the 7800XT is just very good. This is the same guy who said the 4070Ti was reasonable and the 4070 good value.
Good guy Nvidia is the problem with these clowns, they need to moan and complain because that gets them views, but they don't have the ******** to do it with Nvidia as much as they should, Nvidia seeded the AMD blocking DLSS BS to distract from them taking rescores from driver development, they fell for it hock line and sinker but they know that by now and say nothing, nothing at all. Double standards, Predictably.
..come on.. I got thick skin. I can take it
