- 1 Mar 2019
I messaged EK about incompatibility with 360mm rads on the front plate and they said this
“ Thank you for reaching out to EK support.
The radiators mentioned in the description are the maximum radiator size, If you want you can use smaller 360mm radiators and the connections can still be made using the same Matrix7 platform and fittings. ”
Don't get how this makes sense
