Woah was not expecting that so soon!!!i have pre ordered my O11D EVO XL case!
Hardware & Tech News - OC3D.net
OC3D is where you can find the latest PC Hardware and Gaming News & Reviews. Get updates on GPUs, Motherboards, CPUs, and more.www.overclock3d.net
plate looks intresting
This sucks as I literally have triple 360mm and 120mm fans ready to go. Surely theres no way its straight up incompatible? theres got to be a workaround when its a smaller rad than 420?? or do they just mean not compatible with matrix 7 so it will work but just not as easy to install?I see EK have put pre-orders up for the distro plate 429 Euro with release 19th October. Interesting to note only 420mm rads support top and bottom due to case design (360mm still fine without distro)
OCUK sell the vertical and upright kits.Anyone know where I can get a upright adaptor (XL) as I don't think the normal one will work with the XL case?
Looks like they just do not fit when using the distro. Below quote is taken directly from EK product pageThis sucks as I literally have triple 360mm and 120mm fans ready to go. Surely theres no way its straight up incompatible? theres got to be a workaround when its a smaller rad than 420?? or do they just mean not compatible with matrix 7 so it will work but just not as easy to install?
- The Top and Bottom radiator positions are incompatible with 360mm radiators due to O11D EVO XL’s asymmetric mounting pattern.
This is the upright mount you want for the O11D Evo XL: https://www.overclockers.co.uk/lian-li-o11dexl-1x-gpu-bracket-black-cas-lia-00806.htmlAnyone know where I can get a upright adaptor (XL) as I don't think the normal one will work with the XL case?
I'm going to get both the upright and vertical accessories but hold off the 90cm cable until I'm sure which orientation in going to use but this is going to have to wait a couple of months.I'm getting both vertical & upright accessories, as I'm sure I'll change my mind at some pointPlan to use the upright mounting option first though, be nice to display my 4090 Strix.
Who needs 5x optical drive bays in 2023 thoughIt's all a matter of perspective...
I've currently got a Corsair 800D, so although the O11DEXL is ~70mm wider (substantial), it's ~80mm shorter & ~70mm less deep!
Indeed! Although I was using 2 of them (fan conroller & Bay res)!Who needs 5x optical drive bays in 2023 thoughLoads of wasted space in the 800D, it is a big beast though!
Case just arrived. Now just to wait for distro plate and 14900k
sounds like your doing a simular spec to me waiting on the 14900k or 14900KS what motherboard are you going for ?
Also what distro plate?
