Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
I have a basic mechanical rice cooker which is electrically a rearranged kettle. Goes kerchunk at a predecided temperature
For whatever reason giving a rice cooker some conditional code gets to be called fuzzy logic and it has potential to try better settings for a specific outcome vs what you've put in than a basic cooker.
Haven't seen a rice place using one.
Sushi place I go past has two dumb as bricks Buffalo rice cookers. Malay restaurant also has a dumb large capacity rice cooker.
I reckon fuzzy logic attempts to cover weird stuff that consumers do and commercial users that consistently measure correctly and cook one type of rice one way forever have no need of it.
Commercial rice cookers: https://www.catering-appliance.com/rice-cookers all big and dumb![]()
You can, and i can too…with effort, able to do what fuzzy logic does using nothing but a clay pot on an open fire.
The skill here is to know when to turn the heat on high, when on medium and when on low, how long to wait after the heat goes off. A dumb one only has the on/off element. It doesn’t have any of the heating curve element. It usually end up with burnt rice at the bottom, or rice slightly harder in texture. The one in the Zojirushi makes them in the same consistency from top to bottom, all with 1 click. That’s what you are paying for. Commercial ones will have burnt rice at the bottom, i guarantee it….my dad has one of these, and you simply don’t serve customers with these burnt bits that’s all.
