My 7900XTX Sapphire Nitro+ Card is finally on water
Perfect temps and really great hot spot deltas - Max HS my card will see now is in the low 60s to 70c in 4K tested on CoD Shipment for about 2 hours where it really is intensive on the GPU.
I have my settings as follows for 4K @ 120Hz on LGC1 - Its got a lot more head room but HS gets to around 80c for very minimal gains
Thermal Grizzly Kryonaught - Applied a thin layer spread across the whole die and then small dot in the centre and small dots on each chiplets.
Looks like its mounted well as temps are consistent for about a week and getting better with lower ambient temps.
Min/Max Core clock OC 500/2800Mhz
Fast Timings ON Ram OC to 2650Mhz
Stable global undervolt 1100mv
No need for fan profile
Power Limit +10 which gets the board power to about 370watts
GPU Memory temps greatly reduced now sit around 65c on full load
SAM On
Completely Silent operation - 420mm/280mm external rad setup with Be Quite Shadow Wings
For what its worth with the same settings as above I was seeing 80-89c on the stock Sapphire cooler. With GPU memory temps around 82c - Case side panel open and cool air being drawn in.
Watercooling Thread for more pics - https://forums.overclockers.co.uk/threads/watercooled-case-gallery.17305236/page-168#post-36661170
SAM On
