Yeh I was thinking ‘Octopus Flexible’ to get through the winter, then have another look in MarchYou would be semi brave to switch to tracker right now!
Gas has been creeping up.
Its almost certainly going to go up more.
There is also a 9 month cooling off period if you come off tracker, so IMO you should join tracker if your interested in spring because if prices go a bit mad and you come off tracker you stuck until the next autumn!
