500mm max - my tiles were 450x300Hah Shropshire isn't far from me... Which one you go for?
very nice any other flowering bulbs in for the spring? I was going to dump a load of tulips and crocuses in in the next month or so.One and a half kilos of narcissi bulbs going in today. Big yellow trumpets for spring.
Can't beat a long hosepopped to our new screwfix to get a replacement hose for our shower. Mrs likes it longer.
I always thought girth was the important oneCan't beat a long hose
@DJMK4 The brown stains are probably rust. Whole patios can turn brown if you are unlucky with the batch of slabs. Try something like Lithofin Rust-EX or Rob Parker’s Best Rust Remover. Both of those brands have products to deal with mortar stains once you scrape the thick off. Aggressive pressure washing isnt good for sandstones. You can "scar" the surface
You reckon one could cart that up two flights of stairs? Or was it a heavy affair!?I've only ever done it once, but it was a bit of a "mind blown" concept...I used Jewsons...
https://www.jewson.co.uk/p/maxitile-260-tile-saw-belle-grip-240v-JTH2184B (for e.g.)
Deffo!35kgs with off centre c.o.g will be doable but not fun to get upstairs
I’ve been trying to figure this out.. hopefully! Might pop into Jewsons down t’ road.I'd assume the saw seperates from the saw to make it easier to transport?
Would you expect the plumber to check the pressure of the expansion vessel (if your system has one of course) as part of your annual check?
