Are there any good apps for testing for dead pixels etc?
Your eyes? If you can't see any don't worry about them.
We had a box of 20 quest 2s turn up in the office yesterday. They are for another department, god knows what they want them for.
Anyway, as you'd expect I started checking them for dead pixels. Managed to test five of them, all bloody perfect!!!!
My third one is supposed to be coming today.....I know damn well it will have one.
there is plenty youtube videos for testing that, just play one fullscreen and get close to the screen so it covers the entire display/sAre there any good apps for testing for dead pixels etc?
Its not there:system>display>graphics>change default graphics settings
For me it’s there both on my desktop and my laptop but both using nvidia.Its not there:
Just a thought of someone who hasn't a Quest 3 yet, still think its a fair bit on the expensive side,
Considering that the Quest 2 is selling for £300 and is still a good headset, if we take into consideration that tech development marches on, that we can probably buy a more powerful pc today for the same price or even cheaper that a lessor spec pc three years ago, would you not think that the same criteria applies to a VR headset such as the Quest 3?
Just thinking that probably its costing Meta no more to make a Quest 3 than a Quest 2 (taking the Tech marching on factor into consideration) they could probably sell the 128GB version for the same price or a little more than the Quest 2.
Not noticed any flickering, and i've been playing both standalone and virtual desktop.So is anyone else getting slight brightness flicker in Virtual Desktop.? It happens on all 3 machines I have it installed on.
Yeah I’ve done that. It still happens. I’ll be holding them in my hand with nothing touching the trigger, and it thinks my finger is on there.Q2 rose £100 in price for a period, so I'd not expect price cuts too early. Could be wrong.
I doubt they drop the cost as well due to the budget version they're supposedly releasing.
I assume you're putting your controllers down for this? Make sure you've not put them down on the trigger, so it's getting slightly depressed and thinking there's a finger there.
Thanks for the feedback, hopefully more people will chime in and if it turn out to be a hardware issue I will return it within the 30 days rainforest return policy.Not noticed any flickering, and i've been playing both standalone and virtual desktop.
I went from a reverb G2 to a quest pro. the reverb G2 clarity wise is top drawer even now in the sweetspot of the lens it's also higher resolution than anything from meta.Just tried my Q3 on pcvr in Iracing. I'm a bit underwhelmed by the graphics quality. I was hoping it'd be a good deal better than my HP Reverb G2 that I've been using for the last two years.
Not much difference at all as far as I can see. Very much "Meh".
To be fair I've only tried it for 5 minutes with graphics settings I'd been using for the G2. Gotta get off to work now. I'll try having a fiddle with the graphics settings over the weekend.
I abandoned this a while back as it didn't seem to have been updated in a while.Anyone still using Oculus tray tools? What settings are you guys using?
where the new meta headsets really shine over the G2 however is the quality of the lenses. rather than a fairly limited sweet spot you have great clarity over the entire lens.
I'm begining to think you have a faulty unit, my headset is not suffering with any of the issues you are having with yours.This is not the case for me as when I’m moving from the sweet spot I’m still losing a lot of sharpness albeit nowhere near as bad as with fresnel lenses.
Also when looking down there is that double image that’s pinkish in colour.
When I heard people praising pancake lenses and saying you get great sharpness across entire fov I thought it will be exactly the sam as the centre but no, not for me at least.
NopeSo no double image/ghosting at the bottom of the screen for you at all.? (it’s actually green not pink).
Here is a through lens photo showing it.
