Don
- 20 Oct 2002
- Oxfordshire / Bucks
OrderedMaecker
After 10% voucher applied £33
Thanks, I was tempted to get any new headstraps from 3rd party , but you mentioned that one, so i went with that
OrderedMaecker
Yeah they are expensive but they feel very premium and they just work...i love the charging dock it's very well made.Nice haul, I did love my old elite strap for the Quest 2 until it broke.
Cant bring myself to pay the prices for them this time around though.
Automatic account transfer from Q2 TO Q3 is available on setup.Inspired by the thread picked up a quest 3 (already have a 2) that’s arriving today. I’m assuming I’ll need an FB account (set one up for the Q2). Do quest 2 games run “better” or is it a new library?
Time will tell but i'm pleased with mine..the battery life on the Q3 is not great..there is the BOBOVR option if you can find one in stock.Do you feel the meta elite battery pack is worth buying?
I’m tempted to order it but the poor quality and low comfort of the Quest 2 elite strap (non battery) is putting me off the idea?
No i had a BOBO strap on my Q2...it did the job for about £30 no battery though.Did you ever try the Quest 2 elite strap? If so how how does the Meta Quest 3 one compare to that?
Anyone found a way to stop apps from auto updating?
The only way to di it is to turn your wifi off in the headset.
Far from ideal.![]()
I don't want something downloading while I'm playing a multiplayer online
That's also going to a real pain for modded Beat Saber
Yeah it was a brightness flicker was playing phasmophobia at the time. I read somewhere that if you disabled spacewarp it would stop the flicker and it did. Unless it was fluke. I don't know why it would stop the flicker though.What kind of flickering are you getting in VD.? For me it’s sligh brightness flicker.
Unless the Q3 has changes, modded Beat Saber won't auto-update, I have rolled back to 1.28 and just getting a little warning every time I launch it that I ignore.Far from ideal.
For me it is only flickering when using desktop and not in games and now I know why.! it is 120hz that is causing brightness flicker for me and dropping it to 90hz eliminates it completely.Yeah it was a brightness flicker was playing phasmophobia at the time. I read somewhere that if you disabled spacewarp it would stop the flicker and it did. Unless it was fluke. I don't know why it would stop the flicker though.
