- 4 Aug 2007
- Wilds of suffolk
Yup, seems to just be positives so worth doing in my opinion!
Saver sessions last winter would compare your usage reduction for the session period against the same time from previous days but would also take into account if your usage prior to the session was higher than normal. So if you cooked dinner using an electric oven, and did a tumble load just before the session your score wouldn't be as high as if you had typical usage in that period.
This new one looks like it's not doing that so it's a direct comparison with just the same time period and ignores and load shifting you might do.
I could be wrong, but that's my take on it![]()
Other way round. If you in day usage was higher than normal it increased your payout.
This is what was "abused" by some and hence why it has been dropped.
