Quest 3 accessories thread
13 Jun 2013
Just ordered 1 thx. I like cheap n cheerful accessories for my Q3, tbh i've not had a problem with the strap but if this improves things then why not for £9.50 (they've raised the price by £1). Looks like i'll still be able to watch tv/netflix etc with it lying down/back.
17 Aug 2009
Finchley, London
I might get one as well. Also, there's another one on the rainforest for £9.99 called
KIWI design Headset Strap Pad Compatible with Quest 3/2.​
Someone in the comments section of that AMVR video said,
"The kiwi one is even better and cheaper, it lifts the straps off the side of your head a little too"​
I think you have to remove the strap to install it using loops.
20 Apr 2015
Ultimately there'll be many different accessories for the Q3. Top of my list are a halo strap as I don't like headsets clamped to my face. A comfortable facial interface, as the current Q3 one is unwearable, not due to the texture of the material but the shape. Next will be some lens protectors, and that should about do it.
Underboss
OP
20 Oct 2002
Oxfordshire / Bucks
17 Aug 2009
Finchley, London
I'm finding it so much better with the prescription lenses and not wearing glasses anymore. Makes it much easier to put the headset on and take it off. Generally much more comfortable now and I'm still with the stock strap. Although now that the glasses pressing on my nose is not an issue anymore, I'm noticing forehead pressure which is mildly uncomfortable after a while. I'm not sure if I'll need to replace the facial interface or if a halo strap would solve it. But like you, I also want a halo strap so it can sort of float in front of my face rather than clamping it as I think that should alleviate the face feeling squished. So I just want the BoboVR M3 Pro and probably the Soundcore buds and that should do me.
20 Apr 2015
I'll probably go down this route like I did with my Quest 2
22 Oct 2020
Cheers. I was hoping they’d available from UK, how long did delivery take?
31 Dec 2008
I’m now using the 5m powered INIU link cable connected to 5m CSL active USB 3.0 extension cable so I can use my quest in the living room while my desktop is in my office.
It works fine that way and the quest is charging and Oculus software showing 2.3Gbps bandwidth.
The only issue I’m having is that the powered INIU cable can freeze USB port on either pc, quest or both if I connect everything in the wrong order and have to reboot both lol.
