you consume around 500kwh of electricty a month. what do you have that takes up so much electricity?I'm still hiding, and I still haven't added it all up yet, I know roughly and it was reassuringly expensive![]()
Seriously though, compared to some its low, others its high, so I'd say slightly above average usage.That's an average of around 16 kWh a day, background usage is around 500w, that straight away is 12 kWh a day. There is a server running 24/7 (consumes on average 226w), 2 fridges freezers, various networking equipment and other everyday stuff. Oven is electric, we watch TV, use computers etc.
Personally I blame the Mrs, she's always making teaSeriously though, compared to some its low, others its high, so I'd say slightly above average usage.
You sure you only consume 2 kWh a year???? I'm sure you've got something wrong there!i thought i was average. i consume 2kwh a year! a year!
yes, just got my bill yesterday and it still says 2000kwh electricity annual estimate, and it has been for the last 5 years. 10000kwh of gas.You sure you only consume 2 kWh a year???? I'm sure you've got something wrong there!
According to Ofgem the average flat or 1 bedroom house consumes 1800 kWh a year, the average 4+ bedroom house which we come into is 4100 kWh. Going by what I've seen posted on here 6000 kWh a year is quite low compared to some.
you sure its not 2000kwh a year electric and 10,000kwh a year gas….yes, just got my bill yesterday and it still says 2kwh electricity annual estimate, and it has been for the last 5 years. 10kwh of gas.
this is a 4-bed semi-detached. i do have a 2kwh solar panel, but no batteries, so it all gets exported if i dont use it. Taking an average of 4 years of generations gives me 5kwh a day, most of it tends be in the summer, which is then exported out
sorry my bad. i was supposed to type 2k kwh and missed the k@Megahackerd If you run a router 24/7/365 that will use roughly 7.5w, that's 65.7 kWh a year, now you're going to be running a fridge as well, as various other stuff, you see why I don't think your using 2 kWh a year?
2 KW of panels is not going to produce a lot, probably around 2000kWh a year, even if it completely covered you're background usage, there would still be the hours of darkness.
As @Welshman has suggested, its likely to 2000 kWh or 2 MWh, which is far more believable.
yes you are right, i missed the kyou sure its not 2000kwh a year electric and 10,000kwh a year gas….
otherwise it doesnt make sense.
how come victrons are recommended. i see renogy and they seems far cheaper for a charge controllerThink I'll generate 5000kwh for the year, and use under 900kwh from the grid
On another note, Victron prices seem to have come down a lot, the ones you us I think @Ron-ski 45/150 are down to £195 plus vat
If you're building your own system Victron is the way to go really, individual components = easy to replace anything that goes wrong.how come victrons are recommended. i see renogy and they seems far cheaper for a charge controller
Thanks. For my use case (powering lights in the shed and garden) it seem a bit overkill to have that much control, but I can understand in your scenarioEverything has come down in price, would certainly be a lot cheaper now, I also wouldn't build my own batteries, would probably use the Gobal Power batteries.
@Megahackerd As with everything, it depends what you want, how much flexibility, what quality, how much you're willing to pay etc. My inverter can easily exceed 8kW (they do a 12kW one as well) , it was pretty straight forward to connect it up so it could power the entire house in the event of a power cut -and my Solaredge system will keep running then as well.
I wrote my own code which runs on the Victron system to control forced discharging, how many inverters can you do that on?
