wheres NUFC players smashing a bar up?So about half your own fan base then?
Well that's absolutely guttering. When the 8 minute came up, you just knew PSG were going to get some help in injury. What on earth is he supposed to do with his arm in that instance.
what teams had trouble in Newcastle ? dortmund fans loved it here
Yea, we get the exact same comments almost every round of European fixtures. There's been handballs for and against Utd and one against Liverpool in recent weeks that, just like todays, never get given in the PL but will be given in UEFA comps. They have an ultra strict interpretation of handball.European refs are consistent at least, I said that was a pen the second it happened in realtime. Arms anywhere but pinned to your back in the box, you'll give a pen if it hits you.
Nonsense, but consistent nonsense.
Ok, I'm not sure we need you to list reasons why you don't like Newcastle.Didn’t say they did? Although you’re forgetting about that time you smashed your own gaff up and someone punched a horse.
I’m sure the ref is worried about some PSG ultras though![]()
Wrong.European refs are consistent at least, I said that was a pen the second it happened in realtime. Arms anywhere but pinned to your back in the box, you'll give a pen if it hits you.
This is completely wrong. As I mentioned earlier in the thread, UEFA's football advisory board recommended that UEFA change its interpretation of the handball law so that a deflection from a players own body cannot result in a handball but UEFA chose not to implement it. Handballs always have and continue to be given in UEFA competitions in the event of a deflection - the only question mark is the position of the defenders arm and UEFA are incredibly strict on this. If your arm is even marginally away from your body then a handball is likely to be given.Wrong.
If it hits another part of your body before hitting your arm it is not a penalty, even in Europe. That is the simple rule. The fact that the EXACT same thing happened earlier in the game when VAR looked at it and correctly ruled it wasn't a penalty only serves to makes this decision worse.
Even if l give you that. (It is still just ludicrous and will need to change)This is completely wrong. As I mentioned earlier in the thread, UEFA's football advisory board recommended that UEFA change its interpretation of the handball law so that a deflection from a players own body cannot result in a handball but UEFA chose not to implement it. Handballs always have and continue to be given in UEFA competitions in the event of a deflection - the only question mark is the position of the defenders arm and UEFA are incredibly strict on this. If your arm is even marginally away from your body then a handball is likely to be given.
That's how I see it.Even if l give you that. (It is still just ludicrous and will need to change)
Though, the rule stipulates the arm should be in an "unnatural position". Livramento is running, his arm is in a running position and his arm is bent in a running position. It's a shocking decision whichever rule you apply.
And what is an unnatural position is open to interpretation and is different in every League and competition. UEFA have had a very strict view on what an unnatural position is for years now and there's been a lot of pressure on domestic League's to follow suit. I'm sure everybody remembers the start of the 20/21 season when the PL adopted UEFA's interpretation of handball and we were getting penalties every game. The PL ditched it after a few months but it's still in force in UEFA competitions, whether we like it or not.I will give you that. (But it is still just ludicrous and will need to change)
