Winter 2023/24 - It's FREEZING!
Status
Not open for further replies.
Never need an excuse for pierogi and vodka, my liver hates me :D
Makes the liver stronger.
I popped around to my parent's last weekend as we couldn't be bothered cooking. My mum had made a huge batch of pork Kotleti as my brother and his other half had come back to stay.
Couldn't move after having 4!
Finally put heating on for a few hours to get the living room up and to a bearable temp (16c) as it was almost 10c this morning.
You do know this is a false economy. Keep your house and all rooms at a reasonable temperature. Zoning off rooms and dropping them right down doesn't help unless you've highly insulated all internal walls, used thermally efficiently internal doors and put brush strips under of the bottom of them all.
It will then take even longer to heat the room up to temperature again as you're having to heat up the walls, floors and ceiling fabric.
Very light snow in the SW tomorrow morning and with rain not far behind and in front with marginal temperatures - could make things a bit dicey for ice though at some points over Thursday/Friday :(
Nothing much -3C and everywhere is white over with frost - Looks quite wintery looking over the fields.
Must turn off outside taps and drain hose pipes -also drain water butt's.
Was snowing this morning in Blandford. When I looked outside I thought it was frost but when I went out to the car I realised it was infact a very light dusting of snow. and it was still falling very lightly. Earliest snow I've seen in a number of years to my recollection, at least down in these parts.
lovely and cold here this past couple of mornings. can't beat working from home and having the log burner going.......makes for a relaxing mid morning nap :p
Yep, I've started putting the log burner on downstairs. Since it's open plan it warms the whole house instead of spending £10 a day on gas.
I've got a raspberry Pi with a camera module that I've got streaming to my office TV, so I can keep an eye on it while in my office :D
Status
