Never need an excuse for pierogi and vodka, my liver hates me![]()
Makes the liver stronger.
I popped around to my parent's last weekend as we couldn't be bothered cooking. My mum had made a huge batch of pork Kotleti as my brother and his other half had come back to stay.
Couldn't move after having 4!
Finally put heating on for a few hours to get the living room up and to a bearable temp (16c) as it was almost 10c this morning.
You do know this is a false economy. Keep your house and all rooms at a reasonable temperature. Zoning off rooms and dropping them right down doesn't help unless you've highly insulated all internal walls, used thermally efficiently internal doors and put brush strips under of the bottom of them all.
It will then take even longer to heat the room up to temperature again as you're having to heat up the walls, floors and ceiling fabric.
