Had a good play in AMS2 last night, looked amazing. Couple of weird things I've noticed and want to know if others get it before I do a PC wipe to be sure.
AMS2 takes about 3x longer to load a track with the Varjo than it did with the Reverb.
Also I get little moments of stutters every minute or so, as if my FPS is dropping from a stable 90 to 75 or so, it lasts for a second or two then returns to normal. fpsVR monitor shows my frames being stable 90fps throughout?
anyone else get this before I spend half a day doing a PC reset?
omg this fixed so many issues for me it looks amazing now!make sure you use the redshift patch each time you boot it up... makes a nice difference to visuals
i have added this to the first page for ease of access. Thanksmake sure you use the redshift patch each time you boot it up... makes a nice difference to visuals
Yes I think so! Seems a bit weird it’s not standard as it fixes lots of issues for my eyeballsDo you really need to do this patch every time you use it?
yes, I've not used that, once settled on a value, pop it in the config file, then there is no need to change it.In the link there's also a link to a GUI interface so you can test the different levels to find one that suites best
I've not noticed anythign like that, but I haven't tried many different games in VRAnyone come across some games running at ultra-low resolutions, like 640p or something. Even when SteamVR has them showing at running at 4k x 3.5k?
This demo is one if someone could test it?
Surge on Steam
Surge is a short VR music video made by Arjan van Meerten and produced at House of Secrets.store.steampowered.com
