Agreed.Which I personally find quite irritating as I don't want it left on all the time. Having to click an extra menu just to find the off button it is annoying.
The latest update has moved the off button, it's now sleep, and you have to go to further options to turn off.
Doesn't it turn off fully if you hold the power button down until it goes off.
I was under the, possibly incorrect, impression that holding the power button until it fully switches off is supposed to be a last resort, in the same way you hold the power button on a PC for 4 seconds to force it to turn off.
When you hold the power button on the headset it gives the option to power off or restart so it's presumably the same as the shutdown and restart buttons on a PC or phone.
Isn't the latter option more dangerous though as you're circumventing the shutdown process and run the risk of damaging files? I'm sure the risk is minimal but I still wouldn't use that option unless the headset (or my PC or phone for that matter) wouldn't shut itself down when I ask it to.If you short press the power button it gives you the shutdown options. If you keep the button pressed it completely shuts down the headset.
Well that's OK then, and you learn something new every day. Just seemed like the nuclear option holding the button down and not waiting for the shutdown prompts.
Debating getting a Quest 3.
I’ve previously had a Rift and PSVR.
I couldn’t always get on with VR with the motion sickness, but do you think this will be easier to get on with because of the increased resolution and refresh rate?
I also don’t have a gaming PC anymore. Is there enough games and quality of games to just play on the headset?
Played a lot of Beat Saber. Also enjoyed Robo Recall.What games did you play on the Rift? What did you like?
Yes I’ve had a look, there’s a lot on thereErm..... haven't you had a look on the Meta games store.
Shop Meta Quest VR games, apps, deals and more | Meta Quest | Meta Store
Shop VR games, apps and entertainment available on the Meta Quest headsets. Download hundreds of action, sports and multiplayer VR games on Meta Quest.www.meta.com
