- 14 Apr 2014
- Hampshire
Yes but I imagine I wash my car the usual way and would not have to apply it every time if its lasting?it lasts quite a while ! much longer than RainX
i clean it, clay it, then apply it
Wet coat is supposed to be very good and easy to apply
www.highdefinitiondetail.co.uk
This bead coat is supposed to do well too.
High Definition Detail BEAD COAT (Spray On Rinse Off Paint Sealant)
Introducing Bead Coat, the ultimate spray-on, rinse-off paint sealant designed to make protecting your vehicle's surfaces easier than ever.Key Features:Easy Application & Durable Protection: Bead Coat is formulated for effortless application, ensuring that anyone can achieve professional-level...www.highdefinitiondetail.co.uk
How long does Gyeon wet coat last? And does it leave any wax residue behind at all if left a little too long?
Left some AG Prizm on while it was still raining and it left residue.
@Gilbert89 you reckon Aqua coat on sale is a no brainer. If so I'll grab 2 x litre bottles. Also is this ebay link the same product or a variation?
Auto Finesse AQC500 1L Aqua Coat Hydrophobic Rinse Aid 1 Litre Spray Gloss 784672119818 | eBay UK
Car Parts & Accessories. Car Tuning & Styling. Water will simply bead or run off the surface and particulates aren't able to stick. 4.22 We prohibit the audio or video recording of any of our professional or technical Services, or training and consultancy without our prior written consent.www.ebay.co.uk
Just ordered 2 Bottles of Auto Finesse Aqua Coat as they currently have 1Litre Bottles for £6 odd.
Can’t complain for the money, such easy to use protection which provides lovely water behaviour and beads!
Shame they have dropped the free shipping but still worthwhile.
Gyeon Wet Coat is still my favourite as water behaviour and beading is that bit better but I’ve ended up with 2Litre for what 500ML of Wet Coat would cost![]()
10% discount on newsletter sign up. Went in with a mate and got 2 bottles for myself and free delivery.Where is it on sale for £6 per litre?
It was off the top of head £6 ish
- Directly from Auto Finesse.
Can use 10% Off from Newsletter as mentioned.
They used to offer Free Shipping, £3.95 the shipping was for meStill a bargain.
Yeah absolutely. The 1 litre is cheaper than the 500ml on their website. Also buying individual 1 litre is also cheaper than the 5 litre. I went half way with 3 litres!
