I've already noticed an increase in posting in the other sub forums. Genuine posts, not spam.
It's likely a return from holidays. However ignoring that. If true then it's predictably had the effect that people have said it would.
But the impact of the work is different.Sounds like its created as much work as it saved.
I think most of their current work is trying to explain it over and over again to people in this thread...
Subscription is not happening. It’s been mentioned a couple of times and every time it’s mentioned, I’d like to shut it down.Subscription is something I’ve seen a couple of people mention, and I don’t think this would be the answer either.
I’m sure the admin team have thought this through long and hard, and I’m sure they’ve dealt with enough cases where the majority of bad sales have been from members who have contributed very little to the community/forum.
So yes, you will have more people spamming more often, but:
1. Access to the forum and MM is a privilege, not a right.
2. It will likely reduce the number of bad sales in the MM.
It’s a solution which involves the most work for the admin team, but I think it’s the only real solution you can use.
I think that the main stance the admin team are taking with this is that it’s a community forum, and if you’re not adding value to it through posting, you don’t get access to the privileges.
Wasn't the whole point to create activity?
No, the point was to remove access to the MM for accounts that aren't being kept active, for reasons that have been outlined already.
The posts about increased contribution to the forums keeping them healthy have generally been in response to the "but I contributed 15 years ago" people, to help them understand why their entitlement to the MM is misplaced.
Spammers get more entitlements. I think that's what will be understood.
Me too.do we have a percentage of bad sales roughly ,5%?. higher/lower, i would be interested to know
Can I set up a subscription model where people pay me to use the MM?Subscription is not happening. It’s been mentioned a couple of times and every time it’s mentioned, I’d like to shut it down.
Perhaps only the hard of listening will think so...Perhaps by the hard of thinking, sure
I can see an opportunity to be paid not to use the forum.Can I set up a subscription model where people pay me to use the MM?
It's created no more work - spam has always been removedSounds like its created as much work as it saved.
A sensless move, was very active in my overclocking days years ago but do other things now. Still occaisionally buy stuff from the MM for me, my kids and grandson encouraging them into computers, gaming etc. At the end of the day members want or need to sell their used items to buy new, and that ability has been reduced what ever way you look at it.
It's really not that hard.So MM access is unilaterally removed. You wouldn't know this was pending unless you had visited the MM and seen the notification. Now it's gone, and a poorly-written first post here says 15 posts in other areas outside MM over a 90 day rolling period in order to retain access.
Further down it states that this requirement is to restore access.
So which is it? Do people have to keep posting to maintain access? A 15 posts per 90-day period running total?
