- 8 Mar 2018
Couldn't wait any longer for the £50 code so gone for a black 1tb ultra, trading my S23 ultra - £546.65 with the free watch through blue light.
I used EPP, Watch Code, £50 and trade in. Ended up at £389 for S24 256GB.Whats codes did you use please?
I have a 10% friends discount and got lucky with a £50 launch code (instead of the case code they promised)
Yeah I used the £50 voucher with no issues.
Is the Ultra worth it over the plus? It looks like main difference is the 200mp camera and the snapdragon chip.
But given the cost of the s24+, I can't imagine the exonsys chip is that bad...?
On paper the Exynos 2400 is superior to the Snapdragon 8 Gen 2 from last year but not quite as good as the 8 Gen 3.Is the Ultra worth it over the plus? It looks like main difference is the 200mp camera and the snapdragon chip.
Outright performance has not typically been the issue, it's battery life / overheating etcOn paper the Exynos 2400 is superior to the Snapdragon 8 Gen 2 from last year but not quite as good as the 8 Gen 3.
That's for sure, obviously there have been no tests done yet but we'll know soon enough.Outright performance has not typically been the issue, it's battery life / overheating etc
Samsung. I bought two for my S22, the 2nd one is still going strong after all this time.Can anybody recommend a good brand for screen protectors? There are so many on amazon, and i have never heard of any of them! Also, are Spigen still good for cases?
You can get TCB to work. Add your items to the EPP store, open TCB Samsung website. Copy and paste EPP link into TCB Samsung window so they use the same cookie session.As I mentioned earlier in the thread I used the 'Perks at work' website which gives a variety of different discounts but then usually gives less trade in value but this time it gave the same as Samsung which made it a better deal but then you can't get TCB as far as I know.
I wouldn't say one is better than the other, they just look a bit different. 100x isnt really something you use to take any real photos anyway, the main improvements are from 5x-10x which are actually usable
