Did you get a chance to play with this yet, Chris? It makes a nice difference to the stats and usability of the dash.Cheers, will check it out tomorrow.
No mate not yet. Family…Did you get a chance to play with this yet, Chris? It makes a nice difference to the stats and usability of the dash.![]()
Understandable mate. Family first!No mate not yet. Family…
In a nutshell yes, only true way to hide from your isp is using a VPN for everything, but then again do you trust the VPN provider not to log data.I did some research into this and it seems pointing your DNS towards a third party DNS resolver (such as Quad9, Cloudflare) encrypts the DNS queries, but after you acquire the IP, you immediately ask for the IP and name of the site in clear text through your ISP. So the ISP can determine where you are visiting anyway.
On the other hand, running your own recursive resolver in Unbound, you eliminate your data going to a third party DNS resolver, however all your queries are sent in plaint text to authoritative nameservers, which your ISP can see. Repeat queries though will then come from the Unbound cache.
So in both scenarios the ISP can determine where you are visiting, so while there is no true privacy, hosting your own recursive resolver would be the better option as you eliminate sending your data to a 3rd party company.
Other factors would be the speed of resolving queries and if you require some type of filtering, either through third party DNS resolvers or using pihole/adguard.
Have I understood this correctly?
Understood.In a nutshell yes, only true way to hide from your isp is using a VPN for everything, but then again do you trust the VPN provider not to log data.
I use Recurse Unbound myself.
the idea behind quad9 etc is to stop anyone snooping into these packets as they leave your home and onto the DNS servers.
You're talking about SNI, the server name indication. It's possible to encrypt this also, and efforts are well underway. For example, Cloudflare, Mozilla/Firefox, Chrome(ium) browsers, Apple and others are now working to close this privacy loophole. A few years ago, the effort started with ESNI (encrypted SNI) but that protocol was later dropped and rehashed into a broader more private ECH (encrypted client hello). If you enable DoH and ECH in your browser and visit a naughty website (ahoy...) on a UK ISP that bans such sites, suddenly you'll find they load fine even without a VPN - provided they're on Cloudflare, as no other big host enabled ECH yet.Have I understood this correctly?
What upstream is blocky pointing to?It's nippy I'll give it that.. but that was Local Machine vs WiFi fetch from my pihole to be fair. I would need to test more!
I was going to try it, but lowest spec was arm7 so it I just tried blocky again on RPi1 B+ (amr6) Turbo Mode. pretty much the same although the cache was 8ms vs pihole 5ms.i tried blocky last night, seems ok, nice feature set but lack of native gui, makes it hard to have as main dns server
I then tried Technitium and it seems really good, one big thing for me is it has persistent cache out of the box, something unbound cannot do without 3rd party database, literally one tick box to enable it!
Its recursive like Unbound with DOH support for forwarding if you wish and has built in replication to a secondary Technitium server with proper replication, something AGH and Pihole cannot do without addons/extra tools.
Technitium of course has room to grow but seems good, dev is active, I will test it for a while, this could replace my Adguard Home.
2 Minors are no Gui Dark Mode and also no way to see response times like Adguard shows but have been told its on the way.
You won't go wrong. They are reliable and have excellent malware and threat blocking that's basically unmatched, especially for free.Never heard of quad9 until I just read this thread. I'll give it a try, always used google for some reason or another..
Hopefully not a classic case of "if its not broken - why did you fix it..."![]()
does end to end https encryption exist? i thought only VPN would do this.I was using it the other day, seems fast enough. It also queries root and DNSSEC out of the box and I don't need to read a book full of rubbish to get it to run properly.
Although I am looking for something that Encrypts HTTPS queries end to end with add blocking at the same time without needing to read a book from my local network.
