What's the verdict on the Unifi Express? Pricing seems quite attractive.Wonder why they don't publish the Unifi Express throughput on main spec page but its in the FAQ, apparently it will do 1gb even with various features enabled which is good.
Shame they don't do a 5gb interfaced version, would have been much better in todays market.
It doesn't run Protect so it won't do cameras, also 4 extra managed UniFi devices max so could be limiting if you intend to expand. If you want cameras you'd need a Cloud Key Gen 2 or an NVR, by which point you may as well use a cheap USG plus CKII, or get a UDM/UDM-SE.What's the verdict on the Unifi Express? Pricing seems quite attractive.
If I was to look at a starting point to eventually build out and include a second WAP to extend coverage, and one or two cameras, will it do the job, or need something else?
Weighing up ubiquity vs synology arm.
. I designed and 3D printed it mid last year to help tidy the mess that used to live in this cupboard. It's a stackable modular design based on similar designs on Thingiverse but I modelled each one to fit my specific measurements and components. Each "layer" can be swapped out for a different panel to hold a different component (front and/or back), and likewise for each "spacer" between layers too. Some of the blocks on left hand side contain lugs to mount 120mm fans. I have 2x 120mm Noctua fans at a low RPM to get some airflow over things. Hidden inside at the back are a couple of PoE splitters that splits the power off an ethernet and allows you to connect a regular DC jack to help power other accessories (like the fans and fan controller, or other smart home dongles and internet bridges that usually require USB power). The EliteDesk is my home server running Plex and Home Assistant with masses of internal SSD storage, hence a specific spacer just for a CD drive
(it's actually a BD drive that I use to rip my BD's and UHD's for Plex). I know the Unifi kit isn't the latest and greatest but it's been an absolute solid workhorse and continues doing so. Just need to do more cable tidy as always!
Thanks that's very helpful*snip *
I'll give it a goHonestly no idea, it's not something I generally track. If I need something, I just print it and when I get low on filament I buy more. I'd guess maybe no more than 1kg spool's worth?? possibly lessAny idea how much that's cost you in filament?
Yeah it's not for me, they should have at least put either a single 2.5gbe LAN port on it or an SFP.On mobile, can’t find the link?
Can anyone link please?
Edit:
Never mind, got the email. Seems like still with 1GBE ports(was hoping for 2.5GBE support.
Improvements
Added support for OSPF, limited to 1 OSPF instance. This requires a UniFi (Cloud) Gateway with firmware version 3.2.12 or newer.
Added TX retry columns to the Devices page.
Added AI Logs Network Viewer.
Added UPnP and Port Forwarding to the Network Viewer page.
Added 1h time range to Traffic Statistics.
Added additional IPv4 and IPv6 information in the ISP Panel.
Added InnerSpace for Network Application Servers.
A powerful deployment visualization tool that allows you to view your UniFi system's WiFi coverage in your own floor plan.
Allow searching clients by 802.1X Identity on the Clients page.
Improved DHCP Leased IP user experience and accuracy.
Improved Network isolation user experience.
Improved Firewall Rule creation user experience.
Improved Topology page user experience.
Improved Traffic Statistics user experience.
Improved Global Device and Client Isolation (ACL) user experience.
Show the assigned IPv6 address in Internet Settings.
List Traffic Rules in the Advanced Section of Traffic & Firewall Rules.
Hide delegation size when IPv6 is disabled in the ISP Panel.
Updated WiFi Network creation user experience when setup contains a 6GHz capable AP.
It will auto-select the 6GHz band and default to Encryption WPA2/WPA3.
Removed Score Page, we're fine-tuning it. It will make a return in a future release.
Removed VLAN range validation in the Internet Settings.
Bugfixes
Fixed inability to create more than 9 pre/post-authorization restrictions in Hotspot Manager.
Fixed the inability to add new payment options in Hotspot Manager in rare cases.
Fixed inability to complete upgrades from 8.0 to 8.1 in rare cases.
Fixed inability to specify external MongoDB.
Known issues
OSPF Default route redistribution is ineffective, this will be fixed in UniFi OS 4.0.
OSPF Hello/Dead values may different between the Network Application and the Configuration on the Gateway.
OSPF Passive Int
I've got the Ultra coming our £30 cheaper than the Lite? (£95 v £125)Why are the Gateway Lite and the Gateway Ultra the same price.
I got the UXG-Lite in January and now this essentially makes it redundant, for a much lower cost. It much be a misprice or I'm a bitI've got the Ultra coming our £30 cheaper than the Lite? (£95 v £125)
I've have probably been tempted by a Gateway Ultra and two access points rather than an Express and an AP. Just a shame it doesn't have POE ports.
